RE: Wierd Question??
Im kinda goin for the look that 95BlazerLt4wd did. i wont have as big of tires, becuase i dont want to trim any. An i just want to make it level so with a 2" body lift an 2" shackles i sould get about 4" all together shouldnt I?
4 in the rear, 2 in the front, honestly it would look stupid as hell... If your worried about breaking parts, dont crank your tbars.
ORIGINAL: 95BlazerLt4wd 4 in the rear, 2 in the front, honestly it would look stupid as hell... If your worried about breaking parts, dont crank your tbars. |
ORIGINAL: WolfPack It all depends. You should be fine with 1', but that will probably only level the blazer, as most trucks and suv's have a bit of forward rake from the factory. I think Matt (otnietdehoooo) did the 1' just to level it, and I don't recall him having any problems as of yet. |
ORIGINAL: otnietdehoooo ORIGINAL: WolfPack It all depends. You should be fine with 1', but that will probably only level the blazer, as most trucks and suv's have a bit of forward rake from the factory. I think Matt (otnietdehoooo) did the 1' just to level it, and I don't recall him having any problems as of yet. |
That's about what I've got. 1.25' in the front, 2' in the back. Waiting on funds for the body lift right now though.
I can't remember what the factory rake is, but 1' shouldn't look too bad. Only problem might come from your headlights being aimed down a little farther from the lean, decreasing the range of your lights. But other than that, 1' shouldn't be toooo bad. |
Wolfpack do you have shackles in the back? Isnt there some way to adjust the headlights? What kind of rims ro you have? I got the same year blazer an color as well, an i think black rims look really good on red blazers.
I'm sure the headlights are adjustable, I just don't know if they can be moved up that much to account for forward rake like that...not sure at all. In my sig I do not have shackles on, just the t-bar lift up front, now I've got shackles on (see Got my shackles on!). Rims are Pro-Comp Series 51s, 15x8 with 4.5' of backspacing.
And yea, red and black is the best combo I think :D |
sweet, cant wait till i get money!
