1986 blazer how to replace dash light
Old Dec 8, 2012 | 02:48 PM
flipster48's Avatar
flipster48 is on a distinguished road
Default 1986 blazer how to replace dash light
how does one do a replacement of the instrument lights..Fuse is ok ,but have no dash lites..control **** will go to the end and turn on the ceiling lite ok..did my best to look up under the dash to see if could get to anything,no luck..any info on what book or website to go to for general help in doing something as simple as changing lite bulb..thanks..colo springs,co
Old Dec 8, 2012 | 05:02 PM
Thogert's Avatar
I'm not 100% sure, but you should be able to pull the trim around the radio off and that should expose the bolts that hold the gauges on the dash.
Someone correct me if I'm wrong please.
Old Dec 11, 2012 | 10:02 PM
abig84's Avatar
another question that is making me think way back. i owned a 83 and a 85. i believe the torx screws are staring you in the face but yeah you may have to remove the ones around the radio to get at a hidden one or two... but yeah should be self explanatory, just start taking screws off.
i remember the biggest pain is actually disconnecting the speedometer cable, it only gives you like a few inches and you have to somehow get your hand back there.
if ALL your bulbs arent working it might be a different issue all together, maybe the light switch is bad, you said you turned it but if it dont work it dont work, if you have electrical diagrams see if you can find the wire that goes to the dash lights and power it from there
Old Dec 12, 2012 | 12:48 PM
neo71665's Avatar
86-94 blazer s-series
Remove the 2 screws under headlight switch, slide panel down and unplug connecters. Set aside
Remove 2 screws under hvac panel. The fan switch and lights has simple electrial plugs, one for switch and one for lights. On the side you can see the cable for the blend door. It has a spring nut that has to be carefully pried off. On the rear there is a clip that has to be unhooked and thatt cable is loose. On the bottom back there is a gaggle of vacuum lines going to a plug with 2 spring nuts, remove those two and it comes off. Sit aside.
On the bottom of the gauge surround there are 2 screws on each side of the steering column, remove. Now in the light and hvac holes you have 2 10mm nuts on each side to remove. The gauge surround should now slide out.
For the actual cluster there is 4 more 10 mm nuts easily to see. Remove those. If you have an auto trans remove the clip to the steering column (might wanna mark it to put back later first). That clip just slides back and off. On 86-89 you have to pull the cluster out enough and remove the speedo cable. There is a tab on the bottom of the cable that pushes towards the cluster and the cable comes off. Then you have to remove the VSS plug with one screw. Later models don't have all this and the cluster just pulls out.
Once the cluster is out the lights will be on the back under 1/4 turn blue,green, or green/blue plugs. Just twist and pull out.
The hardest part is those damn spring nuts/clips on the hvac. They have to be slowly and carefully worked off the plastic stud. If ya break the stud you'll be stuck replacing the hvac part. The little red clip on the back of the blend door can also be a pita but if it breaks a small zip tie can hold it in place.
chase91
Oct 20, 2013 12:52 PM
bobditts
Nov 6, 2010 10:43 PM
K5blazer1986
Dec 4, 2008 02:07 PM
lpaz
Jun 5, 2008 12:36 AM
kdicker1
Jul 27, 2006 11:53 PM
