1990 s10 blazer no spark no fuel at injectors
Old Feb 27, 2021 | 01:29 AM
Ernest Farah's Avatar
Ernest Farah is on a distinguished road
Default 1990 s10 blazer no spark no fuel at injectors
Hey there,
My s10 started acting weird: first, it would lose rpm on gear change or steering turn, idle went rough, then it would die on gear change or steering turn. After a while, i started it up and it straight died on high idle and refused to turn on again.
changed ignition coil, rotor, cap, ignition module, still not turning on. No spark or fuel at fuel injectors so that leaves me with a faulty pickup coil??
If so, is it possible to only change the pickup coil without taking out the distributor? I have a new pickup and a new distributor with everything on it (rotor, pickup, cap, ignition module) What do you suggest? and could it be another problem?
Attached picture is after removing the rotor (was stuck as hell) and..yes..looks nasty. Am I diagnosing this right?
Thanks.
vanwinkle76
Mar 14, 2015 08:31 PM
Yetisarereal
Nov 21, 2014 05:16 PM
Shaggy
Feb 1, 2010 04:47 PM
Jim Tunstall
Oct 14, 2009 01:47 PM
cfurg
Apr 30, 2008 12:31 PM
