1996 Gauges work but no lighting?
Old Apr 14, 2013 | 01:29 AM
Chavisca's Avatar
Chavisca is on a distinguished road
Default 1996 Gauges work but no lighting?
I unplugged my under hood light from my 96 blazer because I never really had use for it. Shortly after it was getting dark while i was driving and flipped my lights on. My gauge lighting did not come on but my gauges and fog and headlights still worked. As does my dome light. No fuse is blown and my seat belt and brake light and check engine light still all work in the ACC position of my ignition. My radio and all work. I plugged back in the under hood light and now that doesn't work. Can someone please give me some ideas! I overheated my truck driving it home in the dark and flipping on the dome light, soon to find out today I need to replace my water pump. I need my lights!
Old Apr 14, 2013 | 08:09 AM
xgiovannix12's Avatar
Does your heater control light up ?? how about other things like switches door switches and so on .
Old Apr 14, 2013 | 09:27 AM
Chavisca's Avatar
Nope, nothing on the dash. The climate controls are still dark.
The dome light still comes on when i open the door. But nothing else.
Old Apr 14, 2013 | 09:37 AM
chevyriders's Avatar
same thing happened to me. it was the switch. the dimmer section of the switch was broke. the whole headlight and dimmer switch is sold as an assembly
Old Apr 14, 2013 | 09:40 AM
Chavisca's Avatar
I don't see why the parts on these trucks are so complicated!
Ill rip into it later today and let you know what happens.
Old Apr 14, 2013 | 09:41 AM
Chavisca's Avatar
Well, my dome light works from my dimer switch. Did your dome light still work when it broke?
Old Apr 14, 2013 | 09:46 AM
yes it still did work. the only thing that didnt work was dash lights
Old Apr 14, 2013 | 09:47 AM
i was skeptical to replace the switch at first because the domelight still worked, but after i tore the dash apart and tested the switch that was the problem
Old Apr 14, 2013 | 09:55 AM
Chavisca's Avatar
Thank you much! Ill let you know what happens later.
Old Apr 17, 2013 | 07:47 PM
Chavisca's Avatar
Okay, so after getting the pump and all back on, i went through my fuses and double checked them.
It turned out i went over and missed a fuse. I feel dumb haha
argon929
May 8, 2014 03:55 PM
agonz164
Apr 20, 2012 02:10 AM
Spectreblazer
Jan 22, 2010 08:59 PM
JasonG
Dec 12, 2005 02:19 PM
