1997 Blazer grounding issue - where to start?
Old Sep 18, 2014 | 08:04 AM
djarvis8's Avatar
djarvis8 is an unknown quantity at this point
Default 1997 Blazer grounding issue - where to start?
Hi.
I've had what seems to be a grounding issue for quite a number of years now. I've been ignoring it. It exposes itself through the gas gauge. The needle sways back and forth when any current is drawn, like a turn signal, brake light, power window, etc. The more the gas tank is filled (the higher the voltage reading on the gas gauge), the more it sways. Attached is a video to demonstrate:
https://drive.google.com/file/d/0B1Z...it?usp=sharing
I've never diagnosed a grounding problem before. Any ideas on where to start?
Thanks!
Vehicle is a 1997 Chevy Blazer 4WD
Old Sep 18, 2014 | 05:15 PM
richphotos's Avatar
Start with the ground strap for the fuel pump/sending unit, It is located at the very rear of the truck in the middle.
To find it easier, look between your wheel and wheel arch and find the fuel pump, follow the fuel pump harness back and it should be attached to a cross member
Old Sep 18, 2014 | 08:51 PM
djarvis8's Avatar
I believe the fuel pump on this vehicle is inside the fuel tank.
jackofblades
Jan 8, 2012 08:01 AM
Dano01
Dec 12, 2010 04:35 PM
99blaz
Apr 11, 2010 11:40 PM
Big O
Jan 31, 2010 09:29 PM
phil01ss
May 29, 2006 09:21 AM
