1997 Blazer rear window lock
Old May 5, 2017 | 05:00 PM
Shredder1's Avatar
Shredder1 is on a distinguished road
Default 1997 Blazer rear window lock
My rear window lock is not functioning at all, to open it I must crawl back there and use a screwdriver to open the window just to get the tailgate open!
Why Chevy designed it this way is beyond me as if the electrical fails there is no mechanical backup by using the key! Anyways are there any ideas to troubleshoot the situation?
Old May 30, 2017 | 08:21 AM
if6was9's Avatar
if6was9 is an unknown quantity at this point
I just developed a problem with my 2 door rear glass not opening. I hear the solenoid, but nothing happens. Noodled around on Youtube and found the plastic rod on the solenoid breaks.
Old May 30, 2017 | 08:37 AM
GreenBlazer2002's Avatar
You will have to disassemble the tailgate and reconnect the junction where the solenoid actuator moves the opening mechanism. This can be accomplished numerous ways. There is a replacement piece on eBay, or you can rig it back together with some stiff wire such as a coat hanger, depending on which part in there is actually broken and exactly how it broke. Good luck.
e602
91
Mar 8, 2015 04:53 PM
Stoober
Oct 15, 2014 03:21 PM
mjsk5blazer
Nov 2, 2010 08:43 PM
rossg
May 27, 2009 07:48 AM
USMaverick101
Nov 20, 2006 01:20 PM
