1998 Blazer Power Seat fix
Old Oct 4, 2011 | 10:53 AM
AndrewRSmall@Hotmail.com's Avatar
AndrewRSmall@Hotmail.com is on a distinguished road
Default 1998 Blazer Power Seat fix
I just fixed the seat on my 98 Blazer. Thanks to everyone who have posted fixes on this site because it has saved me a lot of time and trouble. I had a problem with my power seat (driver side) which was intermittent. When the seat wasn't working it would drain the battery so something was shorting. The wiring under the carpet turned out to be fine but. The problem turned out to be the wire bundle between the seat position switch and the motors was being squashed between the the seat bottom and a metal part of the seat base when the seat was all the way lowered. There was a wire in that bundle that had insulation worn away and was grounding to the metal seat base. I think this was caused by the fact that a couple of the steel wires under the seat that support the foam were broken letting the seat sag a bit. I sealed up the wire with electrical tape so that should fix it for a while. I'll fix the seat support as well at some time.
sportjunkee
Aug 25, 2015 11:59 AM
r_marczak_83
17
Mar 9, 2013 10:33 AM
TrTl
Sep 22, 2012 09:56 AM
Dodge Guy
Oct 25, 2006 08:48 AM
