1998 Bravada AWD dashlight Never lights up?
Old Dec 21, 2018 | 06:33 PM
TheBravadaBooler's Avatar
TheBravadaBooler is on a distinguished road
Default 1998 Bravada AWD dashlight Never lights up?
When I first turn the key before starting the vehicle all the dashlights light up temporarily except AWD, (AWD doesnt even work) No codes are being thrown, everything underneath is connected and looks good, any help is appreciated
Old Dec 23, 2018 | 07:57 AM
chevyriders's Avatar
I'm not too familiar with the bravada, but I would start by checking your fuses. It's possible one that powers the AWD system has blown. Did you scan it with a basic scanner, or one that actually has the capability to read codes from multiple systems individually?
Old Dec 29, 2018 | 04:39 PM
go chevy's Avatar
I am at a loss when it comes too the Bravada also... "ChevyRiders" advice sounds solid though, hopefully you simply have a blown fuse. I also hope whatever the problem is will be a cheap and simple fix for you... Best of all maybe your AWD will start working again once you track down the issue.
Old Nov 16, 2019 | 06:41 PM
bravo99's Avatar
there is an ATC fuse in the underhood fuse box. it is a 20 amp little mini blade. mine has blown three times and we're still chasing that gremlin but when it does I have no front wheel spin whatsoever and no AWD light like I should. when I put in a new 20 amp fuse the AWD light comes on and dry road driving proves the front to be somewhat engaged complete with Crow Hop. there is also a separate four-wheel drive fuse that has never blown and I've never pulled but I believe that one is in the cockpit dash.
Old Mar 1, 2021 | 11:45 AM
Stiner5811's Avatar
Stiner5811 is on a distinguished road
I also have a 98 Bravada and have had for 4 yrs and never had a AWD light but I have had it off road and it worked without a light coming on
Prpsjeans
Dec 28, 2015 01:02 AM
pettyfog
Aug 2, 2011 07:43 PM
victor290301
Sep 20, 2010 02:35 PM
mpaczosa23
Nov 24, 2008 10:39 PM
TripleBlackBlazer
May 10, 2007 06:37 AM
