1999 chevey s10 blazer 4.3 vortec 4x4
Old Feb 16, 2016 | 12:45 PM
lauraframe5's Avatar
lauraframe5 is on a distinguished road
Default 1999 chevey s10 blazer 4.3 vortec 4x4
I have a 99 chevey S10 blazer 4.3 vortec.. I am having issues with my voltage meter bouncing when I am stopped or in park. While in driving it stays at 14 but once I stop and put it in park and allow it to idle it bounces between 9 and 14.. It hasn't home down to 9 since I have replaced the ignition coil, ignition control module, MAP sensor. But its still bouncing and I don't like it... Please help.. I've had battery and altentor tested while on vechiel and I'm told that they are fine..
Old Feb 20, 2016 | 10:33 AM
If your voltage regulator connector on the alternator has one red wire, the problem is in the alternator. It is not always detected by conventional testers and test procedures. It requires more complicated test equipment, (oscilloscope) and an experienced technician to diagnose it.
If the regulator connector on the alternator has 3 wires, this will fix the problem. https://blazerforum.com/forum/tech-a...ference-60425/
kamilkowalski
Apr 30, 2015 08:36 PM
ussexplorer
Mar 31, 2014 09:00 PM
7873surf
Aug 27, 2009 03:53 PM
96blkblazer
Feb 26, 2009 04:29 PM
