1st gen trailer hitch wiring question
Old Jun 14, 2014 | 09:49 AM
yuka42's Avatar
yuka42 is on a distinguished road
Default 1st gen trailer hitch wiring question
I've been wiring up a trailer hitch and I've found the harness in with the jack. Everything except the right blinker wire which is supposed to be dark green. I see a lime green wire (which I tried but doesn't work). I opened up the right tail light and I don't see a dark green wire connected at all. All the wiring appears to be original. Yet no dark green. Any help? Does the right tail light wire go behind the jack?
Old Jun 14, 2014 | 10:10 AM
Right rear should have a dark green, a brown, and a black wire. All being dark colors, it might be difficult to figure out which is which. Using a volt meter or test light will help. Turn the hazard flashers on and probe the 3 wires until you find the one that's blinking. The dark green wire is for the right turn and stop lamp, (same wire).
Old Jun 14, 2014 | 11:20 AM
yuka42's Avatar
hmm. Looks to be a black, brown and yellow wire attached to the right tail light. I'll do the volt meter test to investigate further and report back. Thanks for the reply.
Old Jun 14, 2014 | 02:20 PM
Just to make sure..... right side is passenger side, (when standing behind the vehicle looking at the rear bumper)
Black is ground, brown is tail light. The third wire should be dark green, unless possibly the socket was replaced, in that case, it could be any color
MRBIT
Aug 4, 2012 01:31 AM
1994BlazerS10
Nov 10, 2009 11:06 PM
davidshaw291
Nov 12, 2007 03:53 PM
Strick
Oct 28, 2007 08:02 AM
