2000 4dr brake lights stay on
Old Mar 16, 2023 | 04:13 AM
Phil Manwarren's Avatar
Phil Manwarren is on a distinguished road
Originally Posted by GeorgeLG
How do you know that the fuel pump turns on when you press the brake pedal? Have you verified this with a fuel pressure gauge?
George
no i heard the pump kick on from under neath
Old Mar 16, 2023 | 10:35 PM
GeorgeLG's Avatar
Get under the truck and find the ground connection point for the fuel pump on the left rear frame rail and make sure that all connections are clean, solid and tight.
George
Old Mar 18, 2023 | 03:06 AM
George
ok as soon as the weather brakes around here oh and i allso made a test light for the fuse box ! ill let you know my findings
Old Mar 18, 2023 | 01:01 PM
GeorgeLG's Avatar
If the ground is ok then its most likely a short to power in a wire bundle somewhere like under the drivers side carpet from water leaks and corrosion.
George
A1 Handyy
May 31, 2014 09:36 PM
Rolandtd
Nov 5, 2013 11:24 PM
helm71
Jun 4, 2013 07:20 PM
Steven S. Acedo
May 10, 2012 05:28 PM
MindlessCorpse
Oct 31, 2007 07:01 PM
