Can't enter key fob programming mode.
Old 12-11-2019, 06:52 PM
Thuwaldt's Avatar
Thuwaldt is on a distinguished road
Default Can't enter key fob programming mode.
'I have a '97. Lost the fob some time ago. I have encountered three methods of programming, but none work:
- cycle key on/off twice while holding unlock
- bumper 4 & 8 pins on OBD II
- Locate red programming bumper inside lower dash panel (doesn't exist).
Any thoughts?
Old 12-12-2019, 01:31 PM
christine_208 will become famous soon enough
I've attached a scan of the pages in my 1999 S/T Service Manual on the Keyless Entry system. Maybe this will help. Let us know if it works for you.
File Type: pdf
Old 12-12-2019, 06:48 PM
Thuwaldt's Avatar
yeah, that is a bit different system, I think. Also, notably, I do not have RPO code AU0, but I DEFINITELY had functional keyless In the past.
I've also discovered that where the RKE module is supposed to be (in the kick panel near the OBD II) is actually an interior light module, NOT an RKE module. Where else might it be located if it worked in the past?
TDS-MN
03-29-2012 10:16 AM
ABN31B
01-03-2011 03:34 PM
acfiero
03-30-2010 07:37 AM
midnightbluS10
08-08-2009 08:55 PM
kaejr
07-20-2007 04:59 PM
Quick Reply: Can't enter key fob programming mode.
