2001 s10 blazer starting issue
Old Jul 30, 2018 | 04:21 PM
Odomje's Avatar
Odomje is on a distinguished road
Default 2001 s10 blazer starting issue
I have a 01 s10 blazer that sometimes doesn’t want to start. I turn the key to start and voltage gauge drops and it acts like battery is dead. I can cycle the key and most times it will start on second try.
Battery is newer, alternator is new. All ground wires from battery to frame, engine have been removed, cleaned and reinstalled. All power connections were checked and secure.
Ignition wiring harness has been changed along with lock cylinder.
All this stuff done and it still try’s to act as if better is dead but it will always start with cycling the key.
Also there are no codes in the computer to indicate anything wrong.
Help help help
any ideas?
Thank you
Mars Bars
Feb 20, 2015 03:00 PM
Ranic85
Nov 30, 2011 09:05 PM
DBlaser_ca
Mar 3, 2010 10:32 PM
ToddByers
Aug 29, 2009 08:40 PM
MadMatt
May 22, 2009 10:10 PM
