2004 chevy trailblazer tbz
Old Apr 7, 2024 | 04:08 PM
TrestonAshlock's Avatar
TrestonAshlock is on a distinguished road
Default 2004 chevy trailblazer tbz
Help!! I have a 2004 trailblazer tbz i6 I changed 3 coils and everything was fine a couple days later I changed all the spark plugs and the vvt silinoid and after I put everything back together the cluster illuminates with a check engine light a battery light abs light and brake light gages dont cycle radio dosnt turn on horn dosnt work or keyless entry can't roll up my windows wont crank at all not even a click fuel pump dose prime. Battery was charged and if I bypassed the ignition relay terminal thats suppoed to ground when the pcm tells it to it cranks. The battery went dead and I left it that way for a couple days ans went out and used jumper cables and another car to jump it it cranked with the key but didn't start due to me having low battery at the time then I cycled the key and it went back to doing nothing. The blower motor is about the only thing that works other then the dash clusters. It dose have 309xxx miles on it but I need it to last just a little longer I'm without a car at the moment please give me suggestions on what to replace or try!
Old Apr 9, 2024 | 11:08 AM
GeorgeLG's Avatar
What was the original issue? How much of this was after your work?
George
Old Apr 10, 2024 | 03:30 PM
Default Reply
George
All of it started after the work and then i left the battery dead for 3 days and jump started it and it started right up been starting since then will repost if it starts up again thank you for you time
Old Apr 10, 2024 | 03:33 PM
GeorgeLG's Avatar
So everything is good now?
George
Old Apr 10, 2024 | 03:56 PM
George
well I think it's started 2 days in a row now so im not sure to be honest
not2bad
Jan 7, 2019 06:18 PM
blazerboy53
Aug 12, 2015 07:53 PM
jay1992
Sep 24, 2011 10:08 AM
Charbear
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Sep 18, 2011 12:40 PM
Eric5101
Feb 28, 2008 08:22 PM
