85 k5 interior light problems
Old Sep 8, 2012 | 11:02 AM
lharper's Avatar
lharper is on a distinguished road
Question 85 k5 interior light problems
ok so im new to this forum and not to sure if im posting this right but here it goes..... I Have an 85 chevy blazer k-5 4x4 , i went to put a new cig. lighter in and the hot wire arched off against the ashtray for a sec than stopped, no big deal or so i thought, i probably blew a fuse. I noticed that my dome light stopped working also, so i go an check the fuse box but all fuses are good and the light under the dash still works just fine the only things that stopped working is the cig lighter n dome light ive been tracing wires n looking at diagrams but its a pretty simple setup an im lost at were the problem is??
Old Sep 8, 2012 | 02:45 PM
abig84's Avatar
did you check the actual current through the fuse? sometimes if you just visually look at them they will look ok but can be bad
Old Sep 8, 2012 | 06:02 PM
lharper's Avatar
no i haven't done that yet, I will do that here in a bit, but i'm pretty sure the fuse that runs the light under the dash and dome are the same its the courtesy fuse, (i think) cuz when i pull that fuse out the light under the dash shuts off, i wonder what fuse runs the cig. lighter?
Old Sep 16, 2012 | 05:42 PM
lharper's Avatar
UPDATE: so i been extremely busy and finally got time to winterize my blazer, (topper on, different carb, had time to check the fuses there was a new style fuse up in the horn/dim spot it was blown so that solved my problem with my dome light and cig. lighter. fixed the topper dome light also now i just need to put in a stereo in and hope nobody steals it!!!!! o thanks for the assistance abig84 much appreciated !!!!!
darq
Jun 12, 2012 12:26 PM
oerhill
Oct 8, 2011 12:44 PM
damageinc98
Jul 12, 2010 10:47 PM
necropenetrator
Oct 26, 2009 09:55 AM
upblazer95
Apr 4, 2009 08:27 PM
