91 blazer constant beep
Old Feb 11, 2016 | 02:51 PM
luvgert1991's Avatar
luvgert1991 is on a distinguished road
Default 91 blazer constant beep
When I have my lights on, there is a that beep that never ends, the same one that goes off when you leave the lights on or when the door is ajar. If I have the lights on the inside set on the lowest setting possible the beep goes away but anything above that it beeps and it does not stop. This occurs when I am driving or the vehicle is idle. I don't really want to find the little sound box and unplug it but I will if there is no other solution.
Thank You.
Old Feb 11, 2016 | 04:53 PM
rexmburns's Avatar
Super Moderator
Between this and your other post it sounds like you have a short or two somewhere under the dash. Get yourself a multi meter and become close friends with it and learn to love it lol! Wiring issues are never fun! Start with the fuse(s) that keep blowing and some schematics of your wiring and figure out if you have wires grounding out that shouldn't be. It's tedious but it pays to be thorough and attentive when doing this cause it's easy to miss a small crack or scrape in a wire and if you miss it you will move on and get all the way to the end and end up starting over and find the issue was one of the first you checked.
DuaneP87
Jan 5, 2015 03:02 PM
lazer2000
Sep 16, 2012 11:00 PM
Fermmie
Jun 21, 2010 08:21 AM
Dakota_Don
Apr 7, 2009 02:37 PM
dgastone
Sep 29, 2008 10:17 AM
