91 S10 blazer won't start
Old Sep 13, 2011 | 01:04 AM
djback's Avatar
djback is on a distinguished road
Default 91 S10 blazer won't start
I left my house my car started fine then i went to the gas station and my car wouldn't start. When i turn the key over nothing happenes my radio just turns off so i though my battery was not connected good so i tried that and still nothing. I had my friend come jump it and it started right away. I got home and put a new screw in the positive side instead of this crappy one that wasn't for it. It started up fine by its self after that then i turned it off to check and it would start again. so i tried to move the battery cables nothing still. I tried to jump it still nothing the started would even click. so i took the starter out thinking it was it hooked it to a batter seemed to work fine. so Im wonder if the ignition wasn't grounded or something?
Old Sep 13, 2011 | 01:14 AM
chris015's Avatar
Almost sounds like a bad battery. Run it down to advance auto or autozone etc. they test for free. see what the tests come back with.
Old Sep 13, 2011 | 10:12 AM
djback's Avatar
I put another battery in and did the exact same things so i think its the wiring going to the starter. i took the old starter out it worked fine but I'm going to buy a new solenoid for it cuz it was kind of busted.
Old Sep 13, 2011 | 10:55 AM
Have you monitored the voltage at the starter both on the large cable from the battery & on the solenoid trigger wire (smaller diameter wire on the solenoid) while attempting to start the truck? That should tell you if you have a cable problem once compared with battery voltage while trying to start. There should be little difference from one end of the cable to the other.
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
dcblazer
Nov 20, 2006 10:22 AM
