96 Blazer 20 A pwr accy fuse feels hot
Old Jul 3, 2015 | 09:07 AM
96BlueBlazes's Avatar
96BlueBlazes is on a distinguished road
Default 96 Blazer 20 A pwr accy fuse feels hot
Recently had to change my fuel pump fuse after smelling a burning rubber smell on way home and truck not starting next morning. Very happy it wasn't the fuel pump. While testing other fuses we found this fuse (Pwr Accy) is super hot, is this normal? I'm wondering if I have something electrical going on because my power door locks are not working from the door or the remote when the truck has been driven for awhile (already checked my #7 fuse) and my 2HI light is staying on, my 4lo and 4hi are working fine but the lights never stayed on before. Any thoughts?
Old Jul 3, 2015 | 09:23 AM
Rusty Nuts's Avatar
Fuses are not supposed to get hot. That is not normal. Failures in seemingly unrelated circuits (fuel pump, locks, accessories). Indicate a problem with your wiring harness. I suspect burning wire insulation is what you smelled. Follow the wiring as much as you can looking for burns, corrosion, or rubbing through. Mine was like that on the bracket under the ABS motor.
Old Jul 3, 2015 | 09:42 AM
Ok thanks will check my wiring harness. Pulling it into garage now.
Old Jul 16, 2015 | 09:25 PM
I'm sure it's probably in the wiring harness under the seat but I don't have time to be taking this apart right. In the mean time to avoid anything starting a fire I took out the 20 A pwr accy relay. From what I see on other threads I will have to find the short in the wiring harness under the seat by removing the seat.
Old Jul 17, 2015 | 10:02 AM
Seat removal and pulling up the carpet will be required to inspect the seat wiring harness for damage.
Old Nov 2, 2015 | 07:50 PM
Yeah I figured. I'm lazy in that area. I hate wiring. I don't mind taking lights off or hoses. Like I'm pretty sure I have a Mass Air Flow Sensor problem. I will be going to the junk yard to get another one this weekend. Things like that I can do, but wiring. Err. Let me win the lottery first so I can pay someone else to do it.
xgiovannix12
Jan 31, 2012 01:54 PM
Blessed23
Jan 14, 2011 08:09 AM
David Hineline
May 28, 2010 01:54 AM
ravenhurst
15
Apr 26, 2009 07:53 AM
rirby
Sep 16, 2007 11:20 AM
