96 Tahoe Column components not engaging ignition starter switch
Old Dec 31, 2023 | 12:47 PM
riverbasin's Avatar
riverbasin is on a distinguished road
Default 96 Tahoe Column components not engaging ignition starter switch
I have voltage loss, it occurs at the column ignition starter switch. I remove switch and bench test and it is correctly connecting the path to the hot side of the engine fuse box. But on car it is not.
I can also engage starter, and have great spark. Engine tries to run, but we don't get power to 3 critical run fuses: IGN E, ECM 1, ENG 1.
Watching the key cylinder turn, and the ignition starter switch is removed, I see the internal gearing moving the arm that activates the ignition starter switch.
Some prior history. Car stopped starting and changed out the ignition starter switch 8 / 2022. Afterward, I had to fully turn the ignition switch to engage starter, but it worked. It was notably different than the factory switch I had just removed. This makes me think my underlying problem was probably there already. Car has miles, around 215K.
I see there is a cable that returns to a preset spot that can affect removing a key. And there is the entire casting (named what?) that the key cylinder and the ignition starter switch go into, which is another wear out part. I have no problems with key removal, returning, or operation.
Anyone been here, save me some diagnostic steps?
Old Jan 3, 2024 | 01:51 AM
I'll bump this to get it some attention. It sounds like you could benefit from having a wiring diagram to help you diagnose what is going on. Unfortunately I only have my 99 Service Manual. Perhaps someone else has one for the 96?
Mikk
Mar 20, 2019 02:39 PM
Eagleridge5
May 29, 2013 03:53 PM
jdepew
Apr 24, 2011 09:57 PM
asgeir
13
Aug 30, 2010 08:08 AM
redchevykid
Oct 29, 2005 04:13 PM
