ignition won't engage starter
Old May 28, 2013 | 02:16 PM
Eagleridge5's Avatar
Eagleridge5 is on a distinguished road
Default ignition won't engage starter
For years I have had to pull my tilt wheel all the way down while turning my ignition key in order for the key to engage the starter, as if something wasn't reaching far enough or connecting. Now it won't do anything no matter how hard I pull it down. Is it in the ignition switch itself or is there something getting worn out in the steering column or something else?
It is not the battery or starter, it has to do with the ignition switch. All accessories come on, I think something is worn out and not connecting anymore just related to reaching the starter.
Thanks for any place to start.
Bill
1985 Full size GMC Jimmy 4X4 350 5.7 4bbl 700R4 automatic
Original owner
Old May 29, 2013 | 01:50 PM
70-K5's Avatar
70-K5 is on a distinguished road
I have not had a GM column apart recently but other models have the actual switch lower on the column and a rod connects the switch to the key cylinder. Since the problem has been getting worse over time either the switch, key cylinder or rod have become worn and/or deformed.
Either time to rebuild the column and see what the worn part is or replace it completely.
Old May 29, 2013 | 03:53 PM
Thank you for the response. I think I will yank the column out and just rebuild it. Does anyone know if remanufactured columns are available?
jdmmario
Oct 25, 2014 06:25 PM
lazer2000
Sep 16, 2012 11:16 PM
andrewrj
May 6, 2012 07:28 PM
burfdogg
Jul 3, 2011 08:52 PM
snowman
Feb 1, 2008 11:16 AM
