97 blazer dim headlights
Old Jul 30, 2019 | 01:05 AM
Jacksmith's Avatar
Jacksmith is on a distinguished road
Default 97 blazer dim headlights
replaced all the bulbs, checked the three relays in the glove box and the three on the firewall. Hi beams will not come on and lo beams very dim. I can hear a clicking sometimes between engine and firewall, but its not the relays. Suspect bad ground, how do I locate it?
Old Jul 30, 2019 | 11:27 AM
Does it have the daytime running lights (DRLs)? And to be sure, of the relays you checked, you checked any associated with the DRL circuit, the headlight ground and DRL relay?
Old Jul 30, 2019 | 04:18 PM
Jacksmith's Avatar
Has dlrs, suspect headlite ground which I cannot locate
Old Jul 30, 2019 | 04:57 PM
I know that on the 98+ there's a ground junction under the air filter box on the driver's side just behind the headlight area, bolted to the core support with just a single 10mm bolt I believe, possibly there's one on the 94-97 as well?
sdunkf
Feb 2, 2017 02:23 PM
247monster
Jul 11, 2012 08:41 PM
lunchbox79
Apr 29, 2010 12:17 PM
WickedBerry
Jun 21, 2009 06:52 PM
davtak
Jan 20, 2007 01:32 PM
