Weird headlight glitch
Old Feb 10, 2010 | 09:16 PM
lunchbox79's Avatar
lunchbox79 is on a distinguished road
Default Weird headlight glitch
A few months ago I drove down to see my parents. It's a 200 mile trip. When I was within a quarter mile of the house my headlights completely cut-out. A few seconds later they began alternating between high beams (which I had on when it all started), daytime running lights and no headlights. It kept doing this rotation in an irregular fashion until I turned off my truck.
Any ideas? I'm stumped by this.
Old Feb 10, 2010 | 09:47 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
i'd bet a loose connection either on the headlight or the grounds. the flashing you were seeing was probably from loosing and regaining the connection. unless someone at one time had a weird police pkg setup
Old Feb 16, 2010 | 03:41 AM
awe341's Avatar
awe341 is on a distinguished road
This could also be caused by a faulty headlight relay. I could easily see this happening if the standard headlight relay fails while the high beams are on. You would get a bit of a power struggle of sorts between the DRL's, the automatic headlights and the high beams.
The automatic headlights would try to kick on and fail because of the relay causing the no lights.
Then since the headlights are off the DRL's would try to kick on.
The DRL sensor then tells the regular lights to turn on because it is to dark out and to turn on the high beams because the switch is on for them.
The regular lights are supposed to come on with the high beams but don't because of the bad relay and the DRL's I believe are connected to detect the regular headlights not the high beams. So the DRL's pop on again.
A rather nasty cycle that must have been quite confusing for your poor truck's computer.
If you replace the faulty relay this problem shouldn't pop up again.
Old Feb 16, 2010 | 08:33 AM
Rockdaddy's Avatar
Rockdaddy is an unknown quantity at this point
Same thing just happened to my son's 97 Blazer. I removed the headlight switch and opened up the switch assembly, cleaned up the contact point in the switch and it’s been fine ever since. Good Luck
Old Apr 29, 2010 | 02:44 AM
lunchbox79's Avatar
Default drl glitch
I believe the true problem has revealed itself.
a few weeks ago I heard a clicking in my glovebox. the clicks were random but I noticed my DRL light flickering in concert with the noise. now two days ago my headlights and highbeams stop working altogether and only the daytime running lights work.
thinking it was strange I searched online and believe that the DRL relay behind my glovebox has gone bad, possibly in conjunction with the headlight switch. sooo...
guess I'll be ordering these in the next few days.
I'll update if that fixes the problem.
Old Apr 29, 2010 | 12:17 PM
Let us know how that goes.
valfnbaby
Aug 24, 2012 11:34 AM
Panzer
Dec 18, 2011 12:32 PM
jamie640
Jun 15, 2011 06:13 PM
godfatheritalio
Jul 31, 2009 11:25 PM
gERgMan
Sep 6, 2008 07:27 PM
