97 blazer no start
my 97 blazer had a bad ignition, no instruments worked and key was hot but it would start
replaced the ignition now it wont start, but the instruments work and they key is not needed to turn the ignition switch.
im new to the fourm, thanks guys!
Buddy, you need to use the edit feature if no one else has posted and you want to add information.
Are you sure that the new ignition you installed is connected correctly? If it would start before you replaced the ignition then that's where I'd suggest you start. Is the ignition switch sending power to the starter wire when you turn the key?
djmehkae
Nov 7, 2017 08:08 PM
FreeTime
Sep 8, 2012 01:38 AM
Larhatch60y
Nov 8, 2007 01:05 AM
actionpaintball
Jul 14, 2006 07:53 PM
apekim
Jun 30, 2006 10:38 AM
