97 blazer no start
Old Oct 29, 2013 | 02:11 PM
user_13120's Avatar
user_13120 is on a distinguished road
Default 97 blazer no start
my 97 blazer had a bad ignition, no instruments worked and key was hot but it would start
replaced the ignition now it wont start, but the instruments work and they key is not needed to turn the ignition switch.
im new to the fourm, thanks guys!
Old Oct 29, 2013 | 02:25 PM
user_13120's Avatar
also the battery has to stay on charge constantly or else something kills it.
Old Oct 29, 2013 | 03:15 PM
user_13120's Avatar
no spark, but has fuel pressure
Old Oct 29, 2013 | 03:26 PM
El_Beautor's Avatar
Buddy, you need to use the edit feature if no one else has posted and you want to add information.
Are you sure that the new ignition you installed is connected correctly? If it would start before you replaced the ignition then that's where I'd suggest you start. Is the ignition switch sending power to the starter wire when you turn the key?
Old Oct 29, 2013 | 09:10 PM
user_13120's Avatar
sorry, new to fourm. but yes, the new ignition is installed correctly, all the gauges now power on (they didnt before) everything works properly now
djmehkae
Nov 7, 2017 08:08 PM
FreeTime
Sep 8, 2012 01:38 AM
Larhatch60y
Nov 8, 2007 01:05 AM
actionpaintball
Jul 14, 2006 07:53 PM
