98 Blazer Doesn't Crank
Old Apr 1, 2012 | 12:06 AM
zball94's Avatar
zball94 is an unknown quantity at this point
Unhappy 98 Blazer Doesn't Crank
After my 1998 blazer sat for a few days while I was out of town, it would crank but not quite start. So after a few hours on the charger, I tried it again. Now when I try to start it, I get one click from the starter and everything goes dead. I got the battery tested, and apparently its a good battery. Oh and I tried jump starting, and it made no difference whatsoever. Any ideas?
Old Apr 1, 2012 | 02:11 AM
50lb_cat's Avatar
Could be your starter. Try tapping it with a hammer then try to start it. Also check your battery cables/terminals. Sometimes it helps to have one person tap the starter and another trying to start it.
Old Apr 1, 2012 | 03:11 AM
zball94's Avatar
That's what I was thinking, although that doesn't explain it being able to crank normally the first time I tried it.
Old Apr 1, 2012 | 04:00 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
How long did you try cranking it?? You could have fried it
Old Apr 1, 2012 | 11:13 AM
zball94's Avatar
Not more than 5 seconds per attempt, maybe 3 attempts?
Alright it's on route to the shop now. After sitting overnight, it has regained its ability to crank, but still can't start. Exhaust still comes out the back so it's probably not the fuel pump. Any ideas?
Last edited by swartlkk; Apr 1, 2012 at 03:02 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond and wait for a response. Rules are rules.
Old Apr 1, 2012 | 01:30 PM
xgiovannix12's Avatar
if shes cranking now id test the fuel pressure
96+ Fuel System Diagnosis - Blazer Forum - Chevy Blazer Forums
if you have proper fuel pressure and the leak test is alright
you have no spark you can test the spark by removing the coil wire and put it near the coil port
let someone crank the motor for 1 sec and you should see a nice blue spark
Old Apr 1, 2012 | 02:37 PM
50lb_cat's Avatar
^^^ +1
Buddykitchen
Dec 10, 2016 06:37 PM
lazer2000
Sep 16, 2012 11:16 PM
lazer2000
Jul 9, 2011 03:46 AM
g_mike
Aug 22, 2010 02:46 PM
firemansc32
15
Oct 20, 2009 10:07 PM
