98 Blazer power lock problem.
Hey folks. About two months ago, the power lock fuse started blowing intermittently (every couple of weeks). Replace the fuse and everything worked fine. Last time the fuse blew, I replaced it and none of the power locks worked, but it did not blow the new fuse.
None of the power locks work now. All four doors, tailgate, or rear glass. Can't even open my tailgate now!
Is there a relay or something somewhere that's common to all six locks? Any other ideas?
Thanks in advance!
Dave
Thanks in advance!
Dave
Sounds like you had a short that eventually burned out the wire. Which fuse have you been replacing?
The 5A(?) mini fuse in the panel on the side of the dash(driver side) Don't remember the amperage of the fuse without going to look. It's blue.
There are two fuses used in the power lock system, the MIR/LOC fuse (#7 - 10A) and the LCK PWR fuse (#14 - 15A). What is the label for the fuse you have been replacing?
Also, just in case you didn't notice, the power lock schematic is in my post above.
Do your power mirrors work?
There is also a 3A MIR/LCK fuse 7 under the hood for the switch signals.
Just went out and checked. Been changing #14, a 15A fuse. Checked #7, there is a 5A fuse installed, and it is blown. Don't have a new one right now. Should it be a 10A instead of 5A?
Yes it should be a 10A fuse for #7 in the I/P fuse box on a '98. You may want to figure out why the fuses are blowing. The schematic I attached will give you pretty much all the details you need.
A 5A is probably safe to use, no larger.
Even so, it doesn't mean that a relay is bad. Could still be a wiring issue. The vehicle is 13-14 years old with who knows how many owners.
