98 S10 Blazer transmission gear ind. lights
Old May 17, 2011 | 03:33 PM
blazerfatman's Avatar
blazerfatman is on a distinguished road
Default 98 S10 Blazer transmission gear ind. lights
My transmission gear indicator light in the dash went out. All other lights work. They went out temporarily for a day and then came back on. The following day they went back out and have stayed off since. I can't see what gear I am in and the odometer is also out. All suggestions will be greatly appreciated.
Thanks.
Old May 17, 2011 | 08:01 PM
I believe that this typically is caused by a fault in the cluster itself. Most of the time, it is a cold solder somewhere on the circuit board in the cluster. Many have had luck fixing the problem with a soldering iron and a bit of time/patience.
monette999
May 12, 2015 05:45 AM
bigjhnsn
Apr 23, 2011 11:59 AM
edavison
Dec 20, 2010 09:55 PM
SoapyTheCat
Nov 30, 2010 07:21 AM
8five-k5
Nov 10, 2010 01:00 PM
