99 blazer: Air horn trouble?
Old Jan 3, 2011 | 07:36 PM
Blazer_Man_Dan's Avatar
Blazer_Man_Dan is on a distinguished road
Default 99 blazer: Air horn trouble?
My dad and I installed a 20 amp air horn to my blazer (in combination with the original horn), not realizing the system was using a 15 amp fuse. ended up blowing the fuse! Any advice for adding the air horn with the original horn (piggybacking if you will)?
Old Jan 3, 2011 | 09:19 PM
neo71665's Avatar
relay
Old Jan 4, 2011 | 04:52 PM
problem is that the relay for the air horn is ground triggered, and we want to use the original horn in combination with the new air horn... the biggest problem is we cant find the ground wire! the repair manuel we have does not show the ground wire for the horn.
basically what my dad is trying to do is have two horns triggerd by one "button." the original horn has its own relay, and the air horn has a seperate relay because the original horn's wiring only withstands 15 amps. how can we make this work?
Old Jan 5, 2011 | 01:07 PM
neo71665's Avatar
The factory horn uses the bracket as the ground. Swap the ground and switch wire around on the air horn relay, it will work either way.
Buck731
Feb 28, 2019 04:30 PM
hunter01
Oct 30, 2010 07:41 AM
nofear17bmx
Nov 22, 2007 04:01 PM
clutch
15
Jan 5, 2007 02:58 AM
cowboy35002003
Sep 17, 2006 11:03 PM
