99 blazer alarm problem,heeelp
Old Dec 22, 2011 | 07:28 AM
heartattack's Avatar
heartattack is on a distinguished road
Default 99 blazer alarm problem,heeelp
hello,i've got a problem with the alarm on my 99 blazer,
the slightest gust of wind and of it goes,i believe its the factory alarm,
it seems very sensative, is there anything i can do to decrease the sensativity of it.
i live in the uk and this is my first american truck and its absolutely brilliant, even the wife loves it, which is a plus,
just need a bit of help
thanks.
Old Dec 22, 2011 | 08:07 AM
war00's Avatar
war00 is on a distinguished road
if it is the factory alarm i know in the north american models there is a little black box in the bottom of the dash around the brake pedal that has an adjustment on it you can try that. its covered up by all the plastic which you gotta remove.
Old Dec 22, 2011 | 08:33 AM
thanks for that i will have a look and see if i can find it, mine's a right hand drive so i guess it could be either side.
Old Dec 23, 2011 | 11:20 AM
redcruiser's Avatar
redcruiser is an unknown quantity at this point
HI, I have been told that the UK models had a different alarm system to the US ones and most were disconnected due to problems. Also the mobilizer is different in usage. I assume you have a RHD model. Do you have to use the remote to switch the immobilizer off?
Adrian
Old Dec 23, 2011 | 01:37 PM
hi adrian, yes it is rhd and yes i do have to use the remote to switch the immobiliser off,
i was guessing when i said i thought it was set to sensative,its been ok until the other night when it was a bit windy, it just kept going off.
any thoughts would be welcome,
ivor
Old Dec 23, 2011 | 03:00 PM
redcruiser's Avatar
My Blazer seems to have had the alarm part of the system disconnected or removed before I had it, just the immobilizer left. Have had mine about three years now and have sorted quite a few things on it. Mine is also LPG, had it converted just after buying it.
Adrian
Old Dec 24, 2011 | 03:30 AM
i would like to do something with the suspension to stiffen it up a bit, as it is it feels a bit wallowy, is yours the same.
ivor.
Old Dec 24, 2011 | 10:34 AM
redcruiser's Avatar
Have sent you a PM
racekid88
15
Sep 26, 2009 01:35 PM
HowlingX
Jan 18, 2009 01:30 PM
gocartone
Oct 19, 2007 06:20 PM
wexfordmike
Mar 18, 2007 08:51 AM
mleasure
Jun 7, 2006 09:58 PM
