99 Chevy Blazer won't crank unless i pull the fuses and put back in
Old Feb 28, 2011 | 10:33 PM
mjhoffman48's Avatar
mjhoffman48 is on a distinguished road
Default 99 Chevy Blazer won't crank unless i pull the fuses and put back in
I have a 99 Chevy blazer, 4.7 L, 120k miles. For a while it was taking a minute to start when I put into the run position. It wouldn't crank for a few seconds and then it would start right up. The other day I went to start it and it wouldn't crank over at all. The battery is working, because I have fully functional lights, radio, etc., and the I can hear the fuel pump working (which I just replaced) when I go to start the car. I thought it may be a blown ignition fuse under the hood. Besides the fuses looking a little "burned" where they connect to the metal inside the box, they were not blown. I put the fuses back into the fusebox, and it started right up! Not even a little delay when starting. Turned it off and tried a few more times, and each time it fired up with no problem. Left it sit for a day, went to start it up, and same thing. So I figured why not try the same thing I did the day before. Pulled out the fuses and put them back in, walah! Started up again without any delay. I only checked the fuses though, I did not check the ignition relay. I don't want to continously pull the fuses to put them back in to start my car. What could it be??
Old Feb 28, 2011 | 10:43 PM
What fuse are you pulling out and putting back in? Are the contacts in the fuse box charred?
Old Mar 1, 2011 | 12:10 PM
The ignition A and ignition b fuse underneath the hood. I wouldn't say charred. The contact s on the actual fuse is a little brown.
bryson_horton
Nov 3, 2011 10:23 AM
nineteensixtycaddy
Sep 12, 2010 08:54 PM
bryson_horton
Mar 3, 2010 08:22 PM
bryson_horton
Feb 2, 2010 06:58 PM
crazycz
Jan 30, 2010 10:47 AM
