ABS and Brake light not turning on when I first start the car
Old Jun 27, 2016 | 12:30 AM
Ciscob1582's Avatar
Ciscob1582 is on a distinguished road
Default ABS and Brake light not turning on when I first start the car
OK so I recently took in my 2001 blazer for having the Abs and brake lights on. They told me they would take care of it. When I got it back lights were gone i was finally happy the lights were off. In these recent days I have noticed that the brake light and abs lights don't turn on when you first start the car. All the other lights come on to do their diagnostic when you first turn the car on but for some reason the abs and break light never come on. Any ideas??????
Old Jun 28, 2016 | 06:32 PM
richphotos's Avatar
What did they say they did to it? That is odd that they do not come on with the check bulbs.
I would suspect they removed the bulbs?
Old Jun 28, 2016 | 06:43 PM
Racer_X's Avatar
Racer_X is on a distinguished road
Removing the bulbs is a lot of work.
More likely they pulled the "Brakes" fuse or "ABS" fuse if there is one. That will make the lights go out. I've only ever done this to my own vehicle.
Old Jun 28, 2016 | 06:57 PM
Ciscob1582's Avatar
I will check both when I get a chance to see which one it might be. If I plug in the OBD will it pull up the codes?
Old Jun 28, 2016 | 07:04 PM
Racer_X's Avatar
If the ABS control module has power, a good, higher end scan tool will read ABS codes.
The Bosch OBD-1300 that Oreilly Auto Parts locations have definitely reads ABS and Airbag codes on my 1996 when the "Brakes" fuse is installed. Not sure if yours will have the same controller and work the same way.
If the "Brakes" (or "ABS") fuse is missing or blown, you won't get ABS codes. The ABS controller can't report the codes when it's asleep/dead.
Old Jun 28, 2016 | 08:32 PM
richphotos's Avatar
It is extremely easy to remove the cluster on these things if you know what you are doing.
Old Jun 29, 2016 | 08:23 AM
Racer_X's Avatar
It's still more work than pulling a fuse out.
What evidence do you have that someone who "fixes" the ABS light by killing it to the point where it doesn't power on for the indicator light test when you turn on the key meets your condition, "if you know what you are doing."
Old Jun 29, 2016 | 01:49 PM
richphotos's Avatar
They took it in somewhere to have it fixed, usually those are mechanic shops.
Mechanics should have the knowledge on such a simple subject and if they do not know how to pull a cluster they should not be a mechanic.
I have seen it MANY times in my life where the cluster was removed and a bulb was removed and the person was charged for it being repaired.
I am not sure why this is such a huge issue for you, I am sorry if I struck a nerve
steve72
Sep 1, 2014 11:41 PM
bigchevyguy
Jul 17, 2014 12:46 PM
Diablo1982
Aug 18, 2011 11:08 AM
beastbandit92
Aug 13, 2010 08:24 PM
megtom2
Nov 24, 2007 10:36 AM
