Aftermarket fog lights
Old May 22, 2019 | 07:16 AM
Default Aftermarket fog lights
I installed a new to me brush guard, and 8ve now bee looking into fog lights. I was wondering since mine has the factory fog lights, could I take the wire for those and hook them up to the aftermarket ones? Or even splice into those wires and have another set running off of them? I'm not electrically inclined, but if you explain it to me, I'm sure to figure it out!
Old May 22, 2019 | 10:09 AM
I can't think of any reason that wouldn't work.
Old May 24, 2019 | 09:00 PM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
It probably won't be a problem if they're LED's. You'll just need to keep the amp draw below the rating of the fuse that protects them.
Old May 28, 2019 | 06:55 PM
I'm going to add a couple more to this thread, just in case someone is wondering the same thing.
So I picked up a set of fog lights for 10$ to try out my theory, they are not installed yet, but I will update this thread if t works or doesnt, just in case someone else is wondering.
Old May 28, 2019 | 09:50 PM
N. Jensen's Avatar
I've got my eye on this one... I wanted to do this, but opted for running new wires and relays. I've pulled all that old wiring and have been waiting to install the newer wires. Looking forward to your progress.
Old Jun 1, 2019 | 08:15 AM
Blazer112's Avatar
Blazer112 is on a distinguished road
Default Splices
Using the existing wires will work fine. As previously mentioned, make sure the watts/amps are similar to the stock lights. I would hook up to existing wires as opposed to splicing into them and running “taps”. Automotive wiring is a frugal beast and splices/taps should be avoided if at all possible. If you do tap them, be sure to use water resistant connectors and stabilize the splice so it doesn’t work loose over time.
Old Jun 1, 2019 | 08:43 AM
Thanks for the input! I'm hopefully going to get to it over the weekend, got plans with the wife and kids, so gonna see if I can squeeze it in somewhere
Old Jun 1, 2019 | 04:53 PM
Ok, so it's not a finished product, but I wanted to do a little to see if itll even work like I wanted, and it does.
So for a test, I stripped some wire off the positive to the fog light wire, and added my positive to my aftermarket wire.
I grounded the light to the mounting bracket and brush board.
The lights come on with my factory fog light switch.
Ground wire
Positive wire
Turned on(passenger side not wired yet)
Old Jun 2, 2019 | 05:32 PM
Got it all installed.
Positive from aftermarket to positive of factory.
Negative of aftermarket to ground on brush guard.
Will take nighttime pics when it gets dark.
Old Jun 2, 2019 | 05:51 PM
N. Jensen's Avatar
Whoa, nice work! Might have to try this one myself... But then I won't need my cool lit up rocker switch. Lol
