air bag sensor
Old May 29, 2012 | 09:48 PM
cucv30's Avatar
cucv30 is on a distinguished road
Default air bag sensor
I have a 99 blazer and it has an air bag code which points to one of the sensors, the RH measures 0 ohms and the LH measures 8.5. I have an extra off a 97, the plug is different seems like the only difference. My question is can i use the 97 sensor if i change the plug to go with it.
Old May 29, 2012 | 11:25 PM
Rottidog's Avatar
You'd have to know what wire goes to what line IN on the sensor & even soldered connections with weather resistant heat shrink aren't always the best.
Get the proper sensor - it's 'only' an airbag that could save your life or that of a passenger.
Just my thoughts & welcome to forum!
Old Jun 2, 2012 | 11:06 PM
cucv30's Avatar
Where can one find info on how to test for sure if the sensors are good. It's strange that if i clear the code, the light will stay off for say 20 minutes or so. If I was going to keep it i would just get rid of the light, but since i'm not i'd like to find a fix.
Old Jun 3, 2012 | 12:40 AM
Rottidog's Avatar
Try google for the testing perhaps. Personally I'd look for the same model year blazer in a wrecker & get a 'new to you' sensor for $5 or so. Just make sure the connectors are the same.
Have you searched in here for Air Bag Sensors? Might be some info around about the testing etc of them.
Zane25-hitch
Jan 16, 2010 11:54 PM
Jones98
Dec 23, 2009 01:38 PM
loppy crimp
Mar 3, 2008 01:02 PM
pajama01504
Aug 4, 2007 10:08 AM
boomtruck97
Suspension Tech
Jun 29, 2006 10:00 AM
