All power goes out when trying to turn on
Old Sep 4, 2012 | 04:29 PM
Fosse's Avatar
Fosse is on a distinguished road
Default All power goes out when trying to turn on
I have a 97 Blazer 4 door 4x4. When I try to turn the truck on all the power goes out. Everything! Sometimes if I just open and slam my door shut the power turns back on. Sometimes I have to wiggle the battery. Usually after a couple times of this it starts. Any suggestions would be greatly appreciated. Thanks
Old Sep 4, 2012 | 04:32 PM
xgiovannix12's Avatar
IT can be a number of things... Dirty loose battery cables. Bad terminal bolts on the battery. Loose ground. Check those and report what you find
Old Sep 4, 2012 | 04:48 PM
Fosse's Avatar
Thanks. I will check all those when I get home from work. I have checked to make sure the cables are tight on the battery but will check again. And to make sure, I can find the ground wire coming from the negative on the battery right?
Old Sep 4, 2012 | 05:02 PM
well sometimes side post battery's bolts like to strip.. IT can also be a weak battery.
Old Sep 4, 2012 | 08:41 PM
Fosse's Avatar
I checked the cables. I guess the negative could of been a little loose. I don't really know how to tell though. I also don't know where the ground is. The truck started right up today. This problem only happens sometimes
Old Sep 4, 2012 | 08:47 PM
Check the terminals on the battery... if they move around its loose...
Old Sep 4, 2012 | 09:01 PM
Fosse's Avatar
yeah it moved. not really sure how to tighten though. With all the cars I have owned I have never had to put a new battery in or ever deal with one
Old Sep 4, 2012 | 09:06 PM
richphotos's Avatar
you tighten it with a wrench, and if the bolt is stripped, use a vice grip. Its real simple.
Old Sep 4, 2012 | 09:14 PM
Old Sep 4, 2012 | 09:18 PM
Fosse's Avatar
Thank you. If the problem happens again after I tighten it I will be posting again. It doesnt happen every time I start the truck. So it might be a while to find out. I try not to drive too much
