Alternator cable ???
Old Apr 13, 2015 | 02:03 PM
yako's Avatar
yako is on a distinguished road
Default Alternator cable ???
Hello , I need a pic or info for this cable where is located ?
Is connected to the ground or back stud of alternator ?
Please a pic !!!
Thanks !!!
Old Apr 13, 2015 | 02:16 PM
Jamaroon's Avatar
You need to provide more information for anyone to help you. Where in the engine bay is this taken? Can you trace where the other ends go? It looks like it could be after market to me, in which case it could be anything.
Old Apr 14, 2015 | 11:20 AM
LeWhite's Avatar
Because its black at first look it would be grounded. Back up and take another picture. Does that red cable go to the battery or alt+ ? Do you have a volt meter?
Old Apr 14, 2015 | 12:13 PM
yako's Avatar
Default Alternator wiring ?
Many thanks for your reply , I have 3 cables one red go to battery , the others two goes to ??? + or ground ???
I have volt meter what I do ?
thanks !!!
[/IMG]
[/IMG]
Attached Thumbnails Alternator cable ???-34rae13.jpg   Alternator cable ???-1y681t.jpg
Old Apr 14, 2015 | 03:52 PM
LeWhite's Avatar
With the volt meter set to OHM measure the impedance of that cable to ground. With the motor running measure the VOLTAGE to ground. That should determine where the cable attaches.
Old May 22, 2015 | 10:06 PM
jasongmc's Avatar
jasongmc is on a distinguished road
Default same question
I am actually looking to see where this wire connects. Is it on the alt post with the red wire direct from batt?...or somewhere else. If possible please post what you found and where it should go. Pic would be appreciated. Thanks.
Old May 23, 2015 | 11:14 PM
odat's Avatar
on the 97 that i had it looks like the power wire for the internal power for the inside and it went on the positive lug on the alternator with the red - if your missing power inside [ won't turn over ect. ] it goes there
Old May 25, 2015 | 08:44 AM
jasongmc's Avatar
Thanks Odat. I will try that and let you know if it works.
TexasRider
May 30, 2013 09:10 AM
Squad-6
Apr 22, 2013 02:19 PM
jaxgent
Apr 7, 2011 04:23 PM
nickdouglas
Sep 30, 2009 02:09 PM
Hanr3
Jan 22, 2007 02:30 AM
