Auto dimming mirror
Old Sep 27, 2011 | 09:59 PM
george154302's Avatar
george154302 is on a distinguished road
Default Auto dimming mirror
Second post here as a newbe, Got a auto dimming mirror for my 02LS and it was either on here or on S10 forum that I read that there is a plug for the mirror under the dash for the mirror to plug into instead of running a country mile of wire to hook it up. If this is correct where under the dash would the plug be located? If not what is the easiest hookup/route to wire it up?
Old Sep 28, 2011 | 08:33 AM
bromanjr's Avatar
bromanjr is on a distinguished road
If there is no harness at your current mirror, you will have to run it all yourself using a connector/harness from a donor vehicle.
The auto dimming mirror only requires power and ground to function. If you want the dimming to disable while in reverse, you will need a third wire to the backup switch circuit.
LannyL81
Jan 24, 2015 07:16 AM
showboat
Jan 6, 2012 12:20 PM
JST4SHO
Dec 21, 2011 11:50 AM
LannyL81
Aug 8, 2010 01:01 PM
Jared
Jan 17, 2007 12:46 AM
