Baffeling electrical problem with my 01 Blazer
Old Jun 30, 2013 | 09:52 PM
Whiskey_with01Blazer's Avatar
Whiskey_with01Blazer is on a distinguished road
Default Baffeling electrical problem with my 01 Blazer
Hello all, I have a 2001 Chevy Blazer LS. It has a 4.3 v6, 4wd, 4 door with some electical problems that none of my friends can figure out. The vehicle won't start and right before it died completely it would drive for 5 or 10 min then shut down without warning. When that happened I couldn't get it started again for a day or two then I could drive for another day or two. Now it won't start or even turn over, none of my electronics work at all. I tried the obvious, i.e. jumping it but it did nothing. And I have a friend who is a pretty good mechanic and he didn't have a clue. I am not in a financial spot as of right now to take it to a dealership and get gouged. I was hoping that someone in here might have a suggestion on how to fix it or maybe know what the cost would be to replace a computer or wiring or whatever. Thanks for the help.
Old Jul 5, 2013 | 04:30 PM
Thogert's Avatar
** Moved to lighting electrical **
You should get some responses here.
Old Jul 5, 2013 | 06:18 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Sounds like your ignition switch took a crap (fairly common problem) over time their insulation degrades and they overheat and at first will just kill the engine, usually at a slow speed without warning, most people can start the engine just fine 5 minutes later after it cools. But it will eventually fail. Im not 100% sure this is your problem but your story matches most bad ignition switch cases. There is a procedure for testing the ignition switch on here so do a search for it, and if your ignition switch happens to be bad don't worry its easy to replace
Old Jul 5, 2013 | 10:34 PM
Thogert: Thanks, I appreciate it.
97cherryblazer: I'll have to look into that, I never considered it. Thanks for the help.
JoSHN
Sep 14, 2012 04:56 PM
UNH1286
Feb 16, 2008 05:31 PM
Matty Kling
Aug 22, 2007 01:01 PM
mrartie
13
Jan 2, 2007 09:28 PM
mattphillips4
Sep 3, 2006 02:31 AM
