Battery keeps dying-help!
Old Apr 2, 2018 | 07:39 PM
Accipiter311's Avatar
Accipiter311 is on a distinguished road
Default Battery keeps dying-help!
Hi everyone, I tried searching for similar threads and got nothing, so here goes.
My 1997 Blazer has a huge (50 amp) draw on the battery that doesn't go away when I pull any of the fuses, but does go away if I disconnect the alternator. The alternator tested fine, but my mechanic told me it could pass the test even if the rectifier was burned out. So, I replaced the alternator, the problem went away... And came back within 2 weeks. Brand new battery and alternator. Do I have a different problem or is my blazer just ruining the alternators for some reason? What could cause this?
Thanks in advance,
Tim
Old Apr 2, 2018 | 08:58 PM
GreenBlazer2002's Avatar
Thanks in advance,
Tim
I had a similar issue when I first got mine. Luckily I had the receipt for the alternator and it had a lifetime warranty. Took it to O'Reilly and swapped it out. The one I gave them was only in the truck for about a month. So yes, you could have gotten a bad part. It's happened to me quite a bit. Especially where I used non-oem parts. These things like ac delco, fyi.
sky_blazer
Nov 27, 2015 10:26 AM
blazerboy53
Aug 12, 2015 07:53 PM
Flyboy024
14
Sep 15, 2010 10:51 PM
Wmac
May 7, 2007 06:11 PM
squirrel
Feb 26, 2006 08:24 PM
