Battery and terminal issue
Old May 10, 2011 | 02:20 PM
2002TwoDoor's Avatar
2002TwoDoor is on a distinguished road
Default Battery and terminal issue
I have a 2002 V6 2 door S10 Blazer. The problem that I am having is that the battery terminal wears a gap between the soft metal on the battery and the contact point for the terminal. There are 3 small prongs on the terminal and I can see where the terminal is arcing between it and the battery. I have filed it down but after a week or two I have the same problem. Has anyone else had this problem? I am considering converting to a standard post style battery connection but really don't want to cut off the factory terminals. Please any suggestions would be appreciated!
Old May 11, 2011 | 06:00 PM
Rottidog's Avatar
Does this give you any ideas? If you add 2 nuts then you can leave the nut against the side terminal tight & back off the 2nd nut to add accesories/spade connections.
Old May 12, 2011 | 08:46 AM
Thanks for the help. I was afraid that my only real option was to take the factory terminals off. Guess I better get to cutting. It is almost the weekend.
Cessnaflyer
Dec 25, 2011 10:50 AM
pmezo
Apr 18, 2010 05:13 PM
sifko36
Sep 26, 2008 11:45 PM
blazerscooby
May 3, 2006 11:25 AM
blazerscooby
Apr 17, 2006 10:53 PM
