Bent Front End
Bent Front End
Hey guys, I noticed some odd things with my front end a while ago that really irritate my OCD.
The headlights, both installed correctly, are different space from the fender panels. One is like a full inch, the other maybe a quarter.
I had to trim the end of my bumper in my wheel well because it extended a good inch past where it should line up with the fender flare and actually rubbed my new tires. Only on the driver's side though, and yes, the bumper was correctly on.
What I am curious about is what could be bent? I know this is a long shot but if anyone had any ideas on what COULD be bent, or where I should look to find something bent, please toss them out there. I eventually want to fix this.
All I know is that before I got this Blazer it definitely was in some sort of front end collision.
Also, if I take off my grill, that plastic shroud in front of the radiator is cracked in two.
Edit: Not a clue why I put this in Lighting & Electrical. Anyone care to move it to wherever she should be?
Bumper mounts & we have more than a few of them could be bent. I've removed my front bumper a few times & each time it's a (female dog in heat) to get it back aligned properly. Some of the brackets are | & some are \ or /.
I'd compare left to right in any & every aspect you can think of. Look at bumper mounts, grille clip positions, headlights (because they mount on the front clip that's not attached to the bumper, but the body). L/R & up & down. See what looks odd & then look as to why. Look down the back of the rad at the frame on either side & see if one side is out. If you see something that doesn't add up, look deeper as to why, compare. Look at the metal panel that the headlight rubber stems poke through, look for wrinkles, things that don't line up from one side to the other.
Sorry man, all of that was thinking outloud, in a way. Sounds like things moved to the DS like "they" went through an intersection & got hit on the PS, might even be the end of the frames by the bumper. How do the gaps between the fenders & the doors line up, are they equal on both DS & PS? How does the hood sit, equal all along the sides/fenders?
Finding any dissimilar spaces should lead you to the issue
snowboarder6899
01-12-2008 04:58 PM
