Blazer Instrument cluster
Old Aug 11, 2012 | 02:37 PM
duckland23's Avatar
duckland23 is on a distinguished road
Default Blazer Instrument cluster
Hi Im having some problems with the cluster in my truck . First off I would like to say that the speedo and tac and batt and volts and engine temp gage all work fine . My oil gage will at times when I press the brake will stay or move a litttle arattic movment on my oil gage . My fuel gage will read but will move or do a full 360 turn at times . Im wondering if its the fuel sender going bad or do I have a bad cluster . I got a used cluster from the junkyard to replace it but am unsure if its the cluster going bad in the truck .
I own a 1997 blazer truck with floor shifter .I was wonder also if there is a cluster control board for the 1997 blazer under the dash . .also Could I have a bad ground . I see on the wiring digram it shows Ground G117 . Would anyone know there this ground is at .
Please Help me repair this truck so I can know the proper lever of fuel in the tank . P.s My oil gage will show a little over the 40 mark , meaning its got over 50 psi pressure for the oil . Also My temp gage will read right too . My volts are good also .Just that the oil gage will not be strat on the 40 mark it will move alittle aratic movement .
Old Aug 11, 2012 | 07:24 PM
warthogdriver's Avatar
well if you already have the cluster swap them out. its not to hard.
it does sound like it may be related to your sender. i know that the oil pressure gauge should move a little with acceleration of the truck..as you throttle up the pump builds pressure...so that sounds normal. and if all the other inst. read fine then i would say that is another sign. when my cluster went bad the whole thing went wacky at random, till one day it just died.
Old Aug 12, 2012 | 12:41 PM
Rottidog's Avatar
Warmed up the oil pressure should be above 40 while driving & about 20 when at idle.
Check grounds for sure & this may help as well
https://blazerforum.com/forum/2nd-ge...problem-42968/
Old Aug 12, 2012 | 01:31 PM
duckland23's Avatar
Thanks for that reply to my thread . Ill check that out . I think your right . The ground wires are rusted and need cleaning of rust . Ill check it out . But Im wondering if this is the same a g117 in the wiring scematic .
2manybroke
Nov 26, 2011 06:18 AM
Polygraph
Sep 15, 2011 01:27 AM
n9ktw
Apr 20, 2011 06:58 AM
elementalnature
Mar 24, 2008 05:31 PM
error_401
Mar 17, 2008 06:39 PM
