Blinker Noise Drives Me Crazy!!
Old Jan 14, 2014 | 08:24 PM
offroadsandimports's Avatar
offroadsandimports is on a distinguished road
Default Blinker Noise Drives Me Crazy!!
Ok, so my blinker noise doesn't turn off. It stops when I turn the truck off, but when I turn it on it makes the noise. The actual blinker light doesn't come on though. Sometimes the noise stops or happens very rapidly. Please help me with this because it drives me and my passengers insane.
Old Jan 14, 2014 | 09:24 PM
richphotos's Avatar
Try the blinker relay first, I believe yours is located behind the glove box.
Old Jan 15, 2014 | 08:15 PM
I think we may have already tried replacing that. We replaced something and the blinker sounds slightly different from before, but the problem is still there
Old Jan 15, 2014 | 09:04 PM
richphotos's Avatar
Then next up would be the multifunction lever/hazard switch (I believe that is all one unit on your truck)
Old Jan 15, 2014 | 09:06 PM
99blzr's Avatar
99blzr is on a distinguished road
If replacing the blinker relay didn't work, it may be your turn signal lever on the steering wheel. I had the same issue and installed a new turn signal lever...problem solved. There's a thread on here that I followed and did it myself.
Old Jan 15, 2014 | 09:30 PM
MoneyPit99BlazerLT's Avatar
MoneyPit99BlazerLT is on a distinguished road
That is definitely the multifunction switch in the column. Had same problem, resolved it when replaced.
Old Jan 15, 2014 | 11:25 PM
richphotos's Avatar
3rd person, looks like its time for a new multi function switch.
If the relay did not work ,the only thing that would really cause that is the multifunction switch.
i would check RockAuto Parts Catalog or Amazon.com: Online Shopping for Electronics, Apparel, Computers, Books, DVDs & more for the best prices on one of those.
There are discount codes on this site for rock auto somewhere
Old Jan 18, 2014 | 10:49 AM
metalmeltr's Avatar
metalmeltr is on a distinguished road
When i bought mine there was a constant clicking and an ABS code for brake light circuit malfunction. There was not an abs light. Replacing the multifunction switch repaired it.
Old Jan 25, 2014 | 08:24 PM
okiedoak20's Avatar
there is also the repair for the hazard button, in some cases that is the culprit, not the intire mulifuction unit.. the hazard button pulls straight out... there is a thread on here also about that and also on s10 blazer site
supermario28
Mar 29, 2014 11:21 PM
blazintexas
May 1, 2012 06:01 AM
MisterBrusso
Aug 1, 2011 10:08 PM
trailblazin88
Apr 18, 2011 08:15 PM
glocknpocket
Feb 28, 2008 07:48 PM
