Blower high Speed not working
Old May 8, 2021 | 07:34 PM
Reporter's Avatar
Reporter is on a distinguished road
Default Blower high Speed not working
I have a 2002 Blazer...the two door model. Just today the high speed fan stopped working, it was acting a little strange yesterday...when I selected it, it didn'tcome on at first and then suddenly did...worked fine the rest of the day....there were a couple of times it sort of faltered buyt then came back on. All the other speeds work fine. Am I looking at a bad switch or is it the resistor board that I need to replace? I have had to replace it once before....a year ago I had to replace the blower motor.
Old May 9, 2021 | 10:38 AM
On high speed, the resistor is bypassed and the voltage to the blower motor goes straight through the relay on the firewall. I would start by checking/replacing that. There's also a 30A HVAC fuse under the hood that should be hot at all times. I would check that, too. Don't confuse it with the other HVAC fuses that are 10A and 20A and should only be hot with the ignition on.
Old Jun 19, 2024 | 08:48 AM
HopeFiend's Avatar
HopeFiend is on a distinguished road
Im having that exact problem... ive checked the fuses and no bad fuses... where is that relay located?
deltrons
Jul 22, 2019 03:29 PM
bubman05
Aug 27, 2017 03:55 PM
geofflesehr
Sep 16, 2013 07:26 PM
Izzy207
16
Dec 17, 2011 03:25 PM
73Blazer
Nov 21, 2010 09:07 AM
