blower motor issues
Old 11-09-2013, 07:33 PM
jatkins3983's Avatar
jatkins3983 is on a distinguished road
Default blower motor issues
How do I replace the resistor to the blower motor on a 1999 blazer
Old 11-10-2013, 02:14 AM
odat's Avatar
odat is on a distinguished road
Talking
on the 92 jimmy that i built my 4x4 rx7 out of it was under the hood on top of the blower cover - in my 84 s10 blazer it's on the heater cover behind the glove box - it will be in the main air flow too cool it - it has a elongated plug with 3 or 4 wires, the resistor is held in place with 2 1/8 in headed screws - look under the hood first i will almost put bets its there
Old 11-10-2013, 11:18 AM
It was under the hood
Old 11-10-2013, 05:31 PM
odat's Avatar
musta been asleep at the wheel last night - in the 84 s10 it's under the hood also - looked at my 83 K20 today it's behind the glove box in her - Oh well knew it was behind the glove box in one of the many chevys i own
Old 01-28-2014, 08:37 PM
I replaced the resistor and yet still don't blow on 4
Old 01-28-2014, 09:02 PM
High blower speed does not go through the blower resistor. If high speed is the only speed that does not work, you'll need to check voltage and resistance at the high blower relay, (center of firewall with 5 wires). Only need to check 3 of them, the dark blue and the purple wires are good.
2 orange wires:
One has voltage at all times.
The other one has voltage ONLY with the ignition in the run position, mode switch on HEAT, fan switch on 4, (HIGH).
Black wire must show less than 5 ohms to ground at all times.
Post your results, and we can figure out what the problem is.
Old 01-28-2014, 09:05 PM
Well I got a basic volt reader but no idea what setting to put it on. Any help is awesome
Old 01-28-2014, 09:09 PM
Post a link to the tester that you have, and I'll walk you through the tests.
Old 01-30-2014, 07:03 AM
Awesome. It might be hard to find since it was a freebie from harbor freight
Old 01-30-2014, 07:46 AM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
Look at the back for a brand/model number. Google will yield the results.
Quick Reply: blower motor issues
