Blower motor resistor
Old Sep 1, 2020 | 01:36 AM
jjnemoiii's Avatar
jjnemoiii is on a distinguished road
Default Blower motor resistor
I'm going to replace my blower motor resistor again today as my fan has stopped working. I am doing this about every six months now in my 2004 Chevy Trailblazer. Once I replace the resistor and the fan. I get no air blowing from anywhere at any speed. My model has the automatic temperature controls for driver and passenger. I have found nothing in the Forum life my issue. As soon as I replace the blower motor resistor it will work just fine again. By chance does anybody have any idea why my blower motor resistor keeps failing?
Old Sep 1, 2020 | 10:17 AM
The "Computer Climate Control" systems use a solid state temperature control module instead of a set of resistors.
From what you wrote it is not clear if you have been replacing the blower motor too.
I'd check that your replacement parts are compatible; i.e. that the blower motor is not different for thr Computer Climate Control sytems. If the temperature control module is acting up, be sure to get a quality part. You might even try to get one from a wrecking yard as these seldom go bad.
Old Sep 2, 2020 | 09:31 AM
jjnemoiii's Avatar
I did replace the blower motor once, sorry if I missed that detail. It is indeed the correct part and make sure when I order it To select the one with auto temperature control. I have bought several brands in case one brand was poor quality. Thank you for your assistance.
ChevyFamily
27
Jun 18, 2014 02:48 PM
SRFCDAVE
Aug 31, 2013 10:26 PM
BLKLBL
Nov 5, 2012 07:04 AM
shellos8
Oct 20, 2010 09:10 AM
EnyChevyUK
Aug 25, 2009 07:24 PM
