brake pedal brake switch
I own a 1995 blazer 4 door 4.3 engine, so my tail lights don't work, I have checked bulbs and fuses and have replaced all, but still they don't work, so I bought a switch that goes above brake pedal I have 4 wires but there are 6 tabs on the new switch, any info on this could help. Thank you
Did you pull the connection and see if it would still plug into the switch? Just because there are 4 wires and 6 pins, it doesn't mean that the connector wouldn't go in properly. There may be contacts that don't get used in your particular application.
