Brake switch issue
Old Jun 7, 2015 | 07:25 AM
FFXBLAZER's Avatar
FFXBLAZER is on a distinguished road
Default Brake switch issue
I just got a 96 blazer with 155k, and failed inspection due to the brake dash light staying on, so I ran OBDii and got code C1281 brake switch circuit malfunction. the actual brake lights work just fine, I tried disconnecting the parking brake switch, no luck. so with all said, what could be the culprit of my dash light?
Old Jun 8, 2015 | 08:54 AM
rxjimmy's Avatar
rxjimmy is on a distinguished road
Google is your friend. I found someone else with your problem "Reporting DTC "C1281 - Brake Switch Circuit Fault"
Reply: The ABS module is looking at the voltage on the purple wire coming from the stoplamp switch. It should be 12V when the brakes are NOT applied, and 0V when the brakes are applied.
Read more: http://www.justanswer.com/chevy/5ct3...#ixzz3cTjH8xLk
It turned out to be a loose fuse.
madmack4
May 24, 2012 12:59 PM
zach bjorge
Mar 17, 2011 06:49 PM
cide
Nov 8, 2010 08:17 PM
SCBlazer96
Apr 16, 2010 08:39 PM
JediKnight2
Sep 11, 2008 07:58 PM
