Brightest/widest halogen bulbs?
Old Jan 24, 2014 | 07:23 PM
Rumblur's Avatar
Rumblur is on a distinguished road
Default Brightest/widest halogen bulbs?
I'm deer paranoid, so I'm always looking to increase my night field of view. I've seen the GE Nighthawk and Sylvania Silverstar talked about, is there any feeling out there as to which is the brightest and/or widest field? Or is there a better choice? I'm not interested in the HID or "kit" stuff. Just direct replacement stuff.
Old Jan 25, 2014 | 03:04 AM
Thogert's Avatar
You won't get anything wider with a stock bulb, but osram and phillips make some of the best bulbs, GE is probably a good choice too. Sylvania is just full of s*** when they say XX% brighter and XX% wider. Your best bet would be overpowered bulbs like 90W/100W instead of 55W/60W that come stock. Just plug right in, but draw a lot more power, so your stock wiring may be subject to... um... well... fires... If you don't upgrade to a relay harness.
Old Jan 25, 2014 | 03:47 AM
Diaita's Avatar
I had silverstars for low beams and they did help visibility, but mostly because they are a whiter light than standard bulbs I think. I don't think they helped field of view at all. Driving lights perhaps may work best for you...
Old Jan 25, 2014 | 03:18 PM
burned's Avatar
burned is on a distinguished road
HIR Headlights 9011 9012 bulbs
Because the filament geometry is identical in size, shape, placement, support position etc, cars that call for 9005 bulbs in their headlamps can take the HIR1 (9011) and cars that call for 9006 bulbs can take the HIR2 (9012). A quick and easy modification to one tab on the base is all that is required.
Old Jan 25, 2014 | 06:53 PM
Diaita's Avatar
Have you tried these bulbs? I'm curious about them.
LuvMyTJ
Apr 22, 2010 09:59 PM
gstrat323
Tires and Wheels
13
Apr 22, 2008 09:59 PM
TheDesertFox
May 20, 2006 11:56 AM
dropd4door
Jan 30, 2006 06:18 PM
Blaize70
Apr 20, 2005 12:33 AM
