Bypass theft system?
Old Dec 20, 2016 | 10:31 PM
Nwjudge's Avatar
Nwjudge is on a distinguished road
Lightbulb Bypass theft system?
1999 Blazer, 4DR, 4.3 Vortec, 4WD, 200k miles.
I'm not having any issues with the theft system, but I am looking to bypass it to install remote start (specifically the Viper 5706v. Not my first time installing remote start, however, it is the first time having to bypass a theft system. Are there any specific bypass modules that are better than others, or any easier way of over-riding this? Any installation tips?
Old Dec 21, 2016 | 09:21 AM
Rusty Nuts's Avatar
The anti theft system needs to be disabled through pcm reprogramming. Ordinarily you don't have to sacrifice your security to add remote start. As always, if someone here does know how to bypass the anti theft system please send it to Nwjudge in a private message. That way we're not posting in an open forum how to steal our beloved blazers.
Old Aug 18, 2025 | 11:28 AM
MSerna's Avatar
MSerna is on a distinguished road
Question
Did anyone answer this? I just purchased a 94 s10 Blazer and I can't get it to start. Thinking it's the anti theft Viper system on it. It cranks but doesn't start. There is a mysterious toggle switch under the I/P and I have a keyfob with two buttons.
Old Aug 18, 2025 | 02:38 PM
El_Beautor's Avatar
Typically aftermarket security systems use a relay to cut the starter wire when armed, so most likely if it was the Viper system causing the no-start situation, it wouldn't crank at all.
I'm pretty sure that the factory Passlock system wasn't added to the S-series trucks until the 1995.5 model year, so if your truck is a 94, it likely isn't related to a factory security system either.
The first place I'd start with diagnosing the issue would be with a fuel pressure leak-down test. There's instructions on how to do this test in the Tech section.
98MintBox
Oct 1, 2021 01:07 PM
boutiquegracie
Jan 4, 2012 08:40 AM
spankyy
Dec 18, 2009 06:30 AM
Mammys Car
Jan 9, 2009 05:30 PM
2kblazer
Aug 23, 2008 03:32 PM
