can't connect to my ob2
Old Nov 18, 2021 | 07:02 AM
Phil Manwarren's Avatar
Phil Manwarren is on a distinguished road
Default can't connect to my ob2
can't connect to my ob2 when my tccm is connected
Old Nov 18, 2021 | 07:55 AM
GeorgeLG's Avatar
The TCCM may be corrupting the class 2 data lines which is how the scanner interfaces with the VCM and reads engine data. Do any other problems clear up? Are you having 4wd issues?
What year is the vehicle?
George
Old Nov 18, 2021 | 10:08 AM
George
yes its a 2000 chevy blazer off and on
Old Nov 18, 2021 | 10:41 AM
GeorgeLG's Avatar
You are a man of few words. I am assuming you mean that you have 4wd problems but I don't know if your telling me if you have other problems with other modules.
That said, Something is wrong with the TCCM, its wiring, connectors, power or ground. If your a parts swapper get another TCCM or have your refurbished. If you are like me and don't like potentially wasting money and want a diagnosis first so you know what to fix or replace then test first:
1) Quality of the power and ground to the module
2) Inspect connectors for fit and corrosion
3) Inspect the wiring
4) Isolate and test the class 2 wire from the TCCM to the blade connector near the DLC
5) I am sure that you don't have a GM Tech 2 scanner to diagnose your TCCM so if all good, have a module rebuild house test your TCCM or replace it
Let me know if you need help with any of this.
George
Old Jul 5, 2023 | 11:24 PM
Evdawg42's Avatar
Evdawg42 is on a distinguished road
Default Cig fuse
check cigarette lighter fuse
doublerr120
Oct 30, 2019 10:02 PM
Mike.308
Jun 20, 2019 01:34 PM
jjimmy
Nov 29, 2012 01:33 PM
Nikoli
Apr 17, 2011 02:33 PM
gil
Jan 18, 2011 12:01 PM
